I have a sheet metal part which is bend to a v-shape.
I want to have a cut out across the bend area. How to project that in to a flat pattern and cut out the relative opening size in the part.
Rajesh.
Can you attach the file here?
There are two different techniques.
1. Start a new sketch on one of the flat faces. (not on a workplane) Click the Project Flat Pattern from the drop down under Project Geometry. Sketch your cut profile and then Cut Across Bend option.
2. In later releases - Unfold (not to be confused with Flat Pattern). Sketch your profile and Cut. Refold (not to be confused with Fold).
Another option is to create the sketch, project it as a Surface, then Split and then Thicken/Offset. Then Flat Pattern. Cut edges will be perpendicular to the part Face.
