Solved by CCarreiras. Go to Solution.
Hi!
Yes, is possible.
You have to link the parameters between assembly and the part.
First add the parameters you have in the part in the assembly (user parameters)
you can give a slygty different name for these parameters to recognize them better, ex:
For parameter "with" you can name "With_iam" in the assembly and "With" in the part.
Next create one iLogic rule in the assembly to link these parameters in the assembly, and that's it: if you change parameters in the assembly, they will be changed in the part.
You can even have a box like the image bellow to fill the values in a better way.
