Inventor Forum
Using Tables in Assembly
6 REPLIES 6
513 Views, 6 Replies
I seem to remember from years ago that tables could be used to insert multiple occurences of a single component into an assembly. Is that true or just a dream on my part? Thanks.
6 REPLIES 6
jletcher
Are you talking iparts?
in reply to: jletcher
Yessir, B.L. Oats Mingo Mfg. Inc. Phone: 918-272-1151 Direct Line: 918-212-1214 Fax: 918-212-1214 boats@mingomfg.com
jletcher
Ok so what did you need? Smiley Happy
I have an Inventor assembly that contains an enormous quantity of the same part. Also, there's not much of a pattern so therefore an array does not help much. So I was wondering if I could create a table with x,y,z coordinates of all the insertion points which would drive the insertion process?
jletcher
Look into work points using excel. This may be a good way. Or look into ilogic to control the work point location. You may also want to look at imates to place them using the work point..
Thanks, I just looked briefly into work points and I think thats the answer.
