I am wondering how many times you can use split command on one part?
I have never used split command before.
if you look at the image below, i would like to split this into 4 pieces, and looking for the quickest and the way that makes the most sense way to do it.
Also another side question. is there anywhere i can sign up for free webinars that are good to attend on inventor?
I am not aware of any limitations on number of Split features
- but I suspect there is an far easier technique in this case.
(You will want to become familiar with mutli-body solids techniques or Frame Generator).
http://au.autodesk.com/?nd=classes
