I have two parts almost the same so they overlay each other. Trying to balloon using the select tool and it doesn't work. How do you select the 'second' part in the select tool list to balloon it?
Thanks.
Pete
IV 2012
I would have said "use the Select Other tool" until I tried it... doesn't work! If two components share an edge, for example, I can only pick one of them. The Select Other tool appears, I can scroll to the other component, but when I select it, nothing happens-- no balloon appears, I'm still in pick mode (mouse pointer with +). With some shared edges I can carefully move back and forth across the edge and find a spot where it highlights the other component, but other edges have no such "sweet spot".
If I go ahead and place a balloon for the unwanted component, I can then perhaps move the pointer to the same edge and have it select the other component. In fact, for one edge I tried, it would only pick part 0006 when placing the balloon, but when I dragged the arrowhead, it immediately switched to part 0004 and no amount of dragging would change it back (using that same shared edge).
Looks as if edge selection for ballooning could use a little attention from the programmers (and don't forget that coil apparent edges can't be ballooned at all- try to balloon a spring in an iso view).
It's a good thing I didn't respond after reading the first post, I would have written almost exactly what sbixler did (except I knew a long time ago that it didn't work).
I suspect that Ballooning has been declared "done" and everyone who worked on it moved on to other things (most likely icon design).
