Inventor General Discussion
Valued Contributor
139 Kudos
Post 1 of 9
Using point clouds
3465 Views, 8 Replies
11-13-2012 09:43 AM
I just noticed that 2013 can import point clouds; this is great news.  It's something I'd wanted for some years now. Thanks for adding that autodesk.
There is precious little documentation on this feature.  I can happily index and attach my points (the scaling seems off...even though I set it to 1.0...) but I cannot seem to do much with the points beyond this.  Obviously, I would like to make a surface but the Surface tools don't seem to operate on these points.  There were no options during import, unlike other point imports, to make them show as points, splines, surface.
What can I do with these data?
Thanks!
Inventor Professional 2014
Windows 7, x64
Dual-core i7, 8GB RAM
NVIDIA Quadro FX 880M
HP Elitebook 8540w
I think at this time you would use similar to placing an image on a 2D sketch - for reference.
The point cloud serves as a sort of 3D reference image.  I think you need more expensive software to get some auto-tools for working with point clouds direclty.
438 Kudos
Post 2 of 9
Re: Using point clouds
11-13-2012 11:04 PM in reply to: QuasiMojo
I've never really worked with point clouds, but since they provide points in space i'd imagine you could connect them using 3d-sketches.
You could then use the surface tools with those sketches.
Using IV2015 Pro SP1 - upd.2, Win7-64bit
2,129 Kudos
Post 3 of 9
11-14-2012 05:15 AM in reply to: -niels-
-niels- wrote:
.... i'd imagine you could connect them using 3d-sketches.
Have you tried it?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
438 Kudos
Post 4 of 9
11-14-2012 05:47 AM in reply to: JDMather
Seeing as i've never really worked with point clouds... no.
But i can also imagine that, if you have a lot of points, this can be a near impossible task or at least a very time consuming one. :smileywink:
New Member
0 Kudos
Post 5 of 9
11-14-2012 06:25 AM in reply to: QuasiMojo
I work With Point Coulds on a daily basis but there is little more there than reference information unles you want to do like they said and take forever making a 3d sketch
Brad
Autodesk Inventoruser since 2003
2-6 core i7's in one machine with 32 gb of ram and Nvidia Quadro K5000 running Inventor Pro 2013, Spatial Analyzer, Faro Scene 5.1
2,129 Kudos
Post 6 of 9
11-14-2012 07:05 AM in reply to: QuasiMojo
Valued Contributor
139 Kudos
Post 7 of 9
11-14-2012 09:29 AM in reply to: JDMather
I had a feeling that they were limited to reference geometry, but hoped I was wrong.  Still, that is better than nothing.  Thanks for your input everyone.
Windows 7, x64
HP Elitebook 8540w
501 Kudos
Post 8 of 9
11-14-2012 03:35 PM in reply to: QuasiMojo
Check the Labs, I could swear they had something in there for Inventor surfacing based on point cloud data.  But, like everything else in there, its "use at own risk", not guaranteed to always be available, yadda yadda yadda.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Distinguished Contributor
0 Kudos
Post 9 of 9
03-23-2013 09:19 AM in reply to: QuasiMojo
AutoCAD lets you import a point cloud (I'm on 2011).  If you shade the viewport, you get a sort-of greyscale shaded PC that looks pretty cool.  Zooming and paning around work fine.  All you can really do with it is snap to points and create construction lines.  Then surface from there or import the construction lines into another program for surfacing.
I'm Jonesin' for some serious PC tools.  They sure are slow to come.
