I hope someone can help me with this issue.
I am trying to automate the assembly of defined components using iMates. I created half of the iMate (3x) on each part to be joined together using workpoints and the mate constraint. I named each imate with corresponding names and added the other imate half in the matching list. I then created a composite imate from the three single imates and named them accordingly.
It all worked great until I added a second imate composite for a different component on the same part. The second composite has completely different workpoints assigned and have their own unique names which are specified on their mates matching list.
Now when I insert a part it seems to be confused as to which composite imate to use. Even though the names and matching list are specific about what to mate to.
Am I missing somthing, or is there a restriction to how many composite imate a single part can have?
Maybe there is a better approach, other than imates, I should be using for what I want to do?
Any input you can give is appreciated.
Scott
