Are we able to view-dimension between model surfaces and sketch info? I'm hoping to use some sketch information from parts in my assembly to illustrate something in the drawing.
Here's the situation: All of my assemblies derive from the plan-view sketch of a column-line grid. In the drawing, I would like to locate the model's position from the column-lines, only the lines are buried inside a derived sketch. I can work backwards and create a view-sketch from projected assembly geometry, but I'd like to know if it's possible to use the derived sketch.
I've tried showing-contents and see the 'Get Work Features, Get Model Sketches'.. ..and activate them only to see them appear in the browser and not the view. Is there some other activation required to employ the sketch into the view?
Or is the dilemma that the sketches are from a derived part (just a sketch, really) that makes this difficult? Also...a side question, when I derive a sketch into a part, any sketch-text only derives into a rectangle or circle, as if indicating the text's location. Do we know why this is?
Thanks in advance for any help.
James
