Inventor Forum
Using iLogic to Suppress Detached Centerlines
3 REPLIES 3
jdrwv5
577 Views, 3 Replies
I am currently running Inventor 2011. Is it possible to program iLogic to select and suppress all dimensions/notes that become detached when I change my iPart member within my drawing and to reattach them when I switch back to the original view?
3 REPLIES 3
Curtis_Waguespack
in reply to: jdrwv5
Hi jdrwv5,
Have a look at this thread, and you'll find some ilogic examples that do some of what you're after:
http://forums.autodesk.com/t5/Inventor-General/Hide-un-attached-dimensions/m-p/5031502#M508499
I hope this helps.
Curtis
jdrwv5
in reply to: Curtis_Waguespack
Curtis, thanks for the reply. That is a good piece of code. However, it would appear that it is actually the centerlines that are becoming detached when I suppress certain features. Is it possible to modify the code to suppress the orphaned centerlines as well as their associated dimensions?
Curtis_Waguespack
in reply to: jdrwv5
Hi jdrwv5,
I added an example to the previous thread that will delete centerlines and centermarks.
http://forums.autodesk.com/t5/Inventor-General/Hide-un-attached-dimensions/m-p/5076982#M511120
Note that the example deletes the detached annotations rather than suppressing them. I don't know of a way to suppress them, but you could turn the visibility of them off. However, doing so would not quiet the errors caused by unattached annotations.
To turn off the visibility use this:
oCenterLine.Visible = False rather than oCenterLine.Delete
I hope this helps.
Curtis
