Inventor Forum
Using IAssembly to change the Sizes of Frames (Frame generator)
1 REPLY 1
due303
349 Views, 1 Reply
I wanted to know, if it is possible to change the size of a frame member using IAssembly. (created using Frame Generator)
My skeleton is an IPart, and when I create the Assembly I also create a IAssembly to make me able to change the sizes in the assembly.
I wanted to know, is there any way to also change the size of the frame that I choose to put in a certain location. The width and height, not the length.
I have a picture of the spreadsheet I would like to create using IAssembly.
Was I completely clear?
Could someone help me out?
Thank you very much.
1 REPLY 1
CCarreiras
in reply to: due303
Olá!
I think it's better to have one Assembly for each different kind of frame, and place all within the iAssembly (you can use the same skeleton part for every assembly), and then use supress/Unsupress in the iAssembly to chose the rigth option for each situation.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
