Is it posible to use iMates on iAssemblies?
I now have an iAssembly, using iParts and iMates. When I place my iAssembly in a assembly it doesn't display any iMate symbols
Solved by ACEDeSmedt. Go to Solution.
I found the solution in this tread:
http://forums.autodesk.com/t5/Autodesk-Inventor/Imates-in-Iassembly/m-p/2242151
First you have to make the iMates then the iAssembly
iMates created after the iAssembly will not be visible or work
and, autodesk, your forum mechanism doesn't work in firefox 4
like you can see of my doubl elines every time I put a new line
regards,
regards,
Klaas De Smedt
