Inventor Forum
Using CAD Manager Channel
3 REPLIES 3
wengerbryan
1976 Views, 3 Replies
Inventor 2013 - My end goal here is to notify our users of available updates.  I've given up on Live Updates because apparently it only notifies of service packs and not just updates since update 2 is now available and it isn't registering on live update in Inventor.  My next recourse is to use the CAD Manager Channel to notify users which I have set up via the CAD Manager Control Utility.  I have formatted the xml file per RSS 2.0 and the xml file is in the location where the communication center in Inventor is looking but it says "cannot connect to feed".  The feed location is correct in the CAD Manager Control Utility and the CAD Manager Channel is enabled.  Is anyone using this and if so how?
Inventor 2012 SP2
Vault Collaboration 2013 SP1
Dell Precision T3500, Xeon W3503 2.4GHz, AMD FirePro V4900
Windows 7 64-bit, 8 GB RAM
3 REPLIES 3
Yong.Jing
in reply to: wengerbryan
You could use below link to create special product's RSS with below link.
http://rss-support.autodesk.com/subscription
After the link you required has been created, add it into default RSS feeds at InfoCenter table.
add default RSS
And check the enable options.
After this setting is succeed, you could create a .reg file and import it to other computers.
If you want to know more infomation about the RSS used in the CAD manager utility, please see more details at below link:
http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff4e421d7d11bf108001d-50ac.htm
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
wengerbryan
in reply to: Yong.Jing
Yes, that would be an option, however there is so much other stuff in those feeds that I don't want users wasting time on.  I need something that I have control of content - like the Cad Manager Channel...  So are we saying that the Cad Manager Channel function provided in Inventor actually does not work and there is no way to use it?  Any comments Autodesk?
Inventor 2012 SP2
Yong.Jing
You could unable the RSS feeds at Inventor, and enable the RSS feeds at CAD Manager Utility
Yong Jing
