Inventor General Discussion
Active Contributor
1 Kudo
Post 1 of 3
using a VB.net form with iLogic (Tutorial)
817 Views, 2 Replies
11-29-2012 03:14 PM
Hello All.
I have been using ilogic and Inventor VBA for a few months now, but I still consider myself fairly new to VB.Net
My objective is to create a form in VB.net (using Visual Studio) (As the dynamic nature of the form I need for this project exceeds the capability of the form generation tool provided with iLogic)
With Inventor install (2012) came bundled a few iLogic samples. I took a few hints from the "Railing iLogic Sample Advanced.iam" but I am still trying to figure out how does the VB.net-form communicate with (iLogic) parameters of the inventor file. (I don't know what contents does a .dll carry over from a VB.net project)
Should use:
Dim oUserParameters as UserParameters
Set oUserParameters = invApp.ActiveDocument.ComponentDefinition.Parameters.UserParameters.Item("xxx")
...to change the parameters' values (embedded within the code of the form) or if anyone could explain (or point me towards a blog/tutorial) on how iLogic can read from the form.
I can use the trick explained in this post ("My first plug-in)
http://forums.autodesk.com/t5/Autodesk-Inventor/Check-out-the-self-paced-guide-My-First-Plug-in/td-p...
... but I think I would like this projects applicaion restricted to a single Assembly (.iam file) only.
Both short and long responses will be helpful;
and is appreciated. Thanking you,
Wajih
244 Kudos
Post 2 of 3
Re: using a VB.net form with iLogic (Tutorial)
11-30-2012 08:06 AM in reply to: WHassan
hi, it may be quicker if you post in the customisation area of the inventor forum... just one click away from here.
if i knew a bit about iLogic i would to help but unfortunately i can't. the inventor VBA may help if you want to look into that as well.
best regards,
- Mark
(Kudo or Tag if Solved - it may help others)
PDSU 2015 Windows 8.1, 64bit.
Active Contributor
1 Kudo
Post 3 of 3
11-30-2012 09:09 AM in reply to: Mark_Wigan
Will do that Thanks Mark,
Wajih
