Inventor Forum
Using a part to remove some geometry
18 REPLIES 18
Message 1 of 19
852 Views, 18 Replies
Using Inventor 8. While working in an assembly, Is there a way to use a part to remove material from another part? I know about project geomety, that won't work for what I'm trying to do. Kind of like if you moved one part into another part and do a interference check. The interference would turn red. Is there a way to remove the just red.
Don
18 REPLIES 18
Message 2 of 19
JDMather
Start a new ipt.
Exit sketch mode.
Derive Component the assembly in the new ipt and select to cut the second part from the first. That takes care of a static problem.
If you have trouble figuring out zip and post the iam and two ipts in question.
Now if we could sweep one solid along a path in another solid...
Message 3 of 19
I tried in IV11, but maybe it also works in IV8.
Use derivation to insert the part to use as cut tool (insert as
surfaces) in the part to be cut.
Then use division tool to remove the first geometry from the second one.
M.
Message 4 of 19
While you cannot sweep a part, you can project the part to a sweep profile.
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
wrote in message news:5624668@discussion.autodesk.com...
Message 5 of 19
"Use derivation to insert the part to use as cut tool (insert as surfaces)
Then use division tool to remove the first geometry from the second one."
That's WAAAAY to difficult...use JD's method instead.
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Message 6 of 19
JDMather
Show me an easier way to create this geometry that would result from sweeping an endmill along a path (sweeping a rectangle does not give correct geometry)
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%2011.pdf
One of our local manufacturers designs CATV cable insulation stripping tools and prep tools. The geometry is a bit more complex than the linked tutorial. It is fairly easy to program on the CNC but a real bear to model (unless someone can show me a better way). I have the path from the CNC code - I just need to be able to sweep a cylinder with the resulting intersection removed.
Message 7 of 19
Don,
In R11 or earlier, you can perform Cross Part Promote within an assembly.
1) Edit PartA.
2) Go to Part Features panel and select Promote.
3) Pick PartB in the assembly. OK.
The body of PartB will be copied to PartA. If PartA is empty, PartB body can
be copied as solid. If PartA already has a solid, PartB body can only be
copied as surface.
4) Use Split command to cut PartA using PartB body.
Please note that the copied body is non-associative.
In R2008, the same capability has been renamed and extended. The new command
is called Copy Object. The result can be associative or non-associative
depending on your settings.
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
wrote in message news:5624609@discussion.autodesk.com...
Don
Message 8 of 19
Here's a 2008 example using a sweep and a derived ball cut. See attached...
One way to do it....
260-399-6615
AIP 11SP2, AIP 2008
wrote in message news:5624750@discussion.autodesk.com...
geometry)
removed.
Message 9 of 19
Second try...
260-399-6615
AIP 11SP2, AIP 2008
"Dennis Jeffrey" wrote in message
news:5624813@discussion.autodesk.com...
260-399-6615
AIP 11SP2, AIP 2008
Message 10 of 19
Astonish yourself!
M.
Message 11 of 19
JDMather
Sweeping a rectangle does not result in the same geometry as sweeping a cylinder.
I do not have time to offer the proof right now but this problem has been discussed here in some detail in the past. If someone does not jump in here and show the difference I will come back to this sometime in the future.
Maybe I spoke to soon as I see you have added a guide rail with the path - but I am still very skeptical. Look forward to examining this closer. Message was edited by: JD Mather
Message 12 of 19
JDMather
Ball end mill that does not go below the radius is trivial. An end mill cylinder sweep is much more complex geometry (to model).
This is a subject that I and others have spent considerable time on. I would be very interested in an elegant solution. Message was edited by: JD Mather
Message 13 of 19
tomtan
like this
Message 14 of 19
JDMather
Do that on a path around a cylinder. (in Inventor)
Message 15 of 19
Now I understand what you meant.
> this closer.
No, you are right: the rectangle doesn't keep normal to the path, it
keeps normal to the guide.
M.
Message 16 of 19
JDMather
A rectangle can't work as the tangency between the cylindrical cutter and the sides of the slot is continuously variable. The cylindrical cutter is in effect an infinite number of rectangles arrayed about an axis - not just the one rectangle perpendicular to the path.
Message 17 of 19
Just because this example has the sweep at the radius, does not mean that it
cannot go below the surface. See attached... Of course, at some point you
are going to need to lift the tool out of the part.... 🙂
So, JD, what is your more elegant solution?
260-399-6615
AIP 11SP2, AIP 2008
news:5624891@discussion.autodesk.com...
Second try...
260-399-6615
AIP 11SP2, AIP 2008
260-399-6615
AIP 11SP2, AIP 2008
Message 18 of 19
JDMather
>Just because this example has the sweep at the radius, does not mean that it cannot go below the surface.
I haven't bothered to open your Inventor file to check the geometry but I suspect you are missing the point. Are you familiar with the past work of Jeff Howard on this type of problem? Did you roll up the EOP? That file size looks rather large. I am on a 26.4Kb DUN. (yes I typed that right)
Where did I say I had an elegant solution? The best I can do is the cited tutorial borrowed from Jeff Howard.
Message 19 of 19
> the path.
I think that the rectangle could work, but it has to be perpendicular
to the path. My attempts seem to have failed this goal.
I tried to change things in order to make it possible (see attached
cam.ipt).
But I could sweep as surface, but not as solid.
The assembly should show that the surface could really be the path for
the follower. Try to animate the constraint named DRIVE_ME.
Now I think that Inventor developers have a new problem to solve: why
the profile sweeps as surface but not as cut?
M.
