Inventor Forum
User Interface Survey: Share your thoughts by 2/15/12
14 REPLIES 14
Message 1 of 15
smithar
1650 Views, 14 Replies
Inventor users, we need your feedback!
The Inventor product team is committed to delivering the best product experience and value for you and your company. In recent years, we’ve focused on enhancing user interface elements including the ribbon toolbar, direct manipulation, mini toolbar, and marking menu. These enhancements are intended to allow Inventor users to increase productivity, streamline common tasks, and customize certain aspects of your individual workflow. Your answers to this 10 minute survey will help us understand what matters most and guide our efforts to continuously improve the Inventor user experience.
We want Inventor to be the best product possible. Please let us know what matters most to you.
Take our short survey here.
Adam Smith
Product Manager for Inventor
14 REPLIES 14
Message 2 of 15
Scotty87
in reply to: smithar
One thing I think Inventor really needs is for the browser bar to have tabs, similar to the ribbon; clicking twice to reach the vault browser (and to get back to the model browser) is a real pain when you're doing it all day. It would also prevent the iLogic browser from taking up space in the model browser.
Where the browser headlines currently looks like this: (I hope this makes sense...)
| Model v |
       | Vault |
| iLogic
I'd suggest something like this:
|Model | Vault | iLogic |
Message 3 of 15
SBix26
in reply to: Scotty87
Good idea-- submit that through one of the official wish lists, either AUGI or Autodesk, or maybe even both.
Message 4 of 15
Vlad.Makarov
Hello Mr. Smith, Thank you for the hilarious survey.
______________
Inventor Pro 2012
Vault Pro 2012
Message 5 of 15
Vlad.Makarov
Sorry Scott, that is not the Autodesk way. In the 2013 version it will take four clicks & in the 2014 version, six.
They need to add the clicks so that in 2016 they can turn around & take them out. Then marketing will trumpet the new & improved version which will be back down to two clicks.
______________
Inventor Pro 2012
Vault Pro 2012
Message 6 of 15
mflayler2
in reply to: Vlad.Makarov
I would like to see more of a palette type interface for parameters like AutoCAD.  Would make the transition for them easier which is the whole idea anyway right?
Having the parameters table, ilogic, and on the higher end side, the Factory Asset tools and the Jig and Fixutre preview as this type I would see as a benefit.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 7 of 15
karthur1
Scott,
I know exactly what you mean. I suggested this a couple yrs ago... still waiting...Talk about repetitive injury.......I'm so sick of having to click twice just to get to the vault menu then two more clicks to get back to the model menu. Here's what I have done.
1. Added this code to my "Default.ivb".
Sub Toggle_Model_Vault()
On Error Resume Next
If ThisApplication.ActiveDocument.BrowserPanes.ActivePane.Name = "Model" Then
ThisApplication.ActiveDocument.BrowserPanes.Item("Vault").Activate
Exit Sub
End If
If ThisApplication.ActiveDocument.BrowserPanes.ActivePane.Name = "Vault" Then
ThisApplication.ActiveDocument.BrowserPanes.Item("Model").Activate
Exit Sub
End If
End Sub
2. Assigned a short-cut key to the macro (Via Tools>Customize, Keyboard tab).
Now to toggle between the two I can just press the assigned key.
Only caveat is that in 2012 the leyboard customization does not hold when I exit Inventor... : (.  The solution to this is to export it, then import each time I start Inventor.... another reason that I refuse to load 2012, but thats another topic all together.
Hope this helps.
Message 8 of 15
splinemadness
I recommend not fiddling with the interface further while there are issues that significantly increase the work load of the user.  Specifically, Inventor isn’t very “robust” – sweeps, lofts, and large (I.E. the size you want) fillets often cause manifold problems and fail even though its easy to imagine in your mind what you wanted the program to do.  Two dimensional sheets can result when an outline is projected and then used to cut material away.  Lines that snap to one another often fail to create coincident constraints, and it can be difficult to close even simple loops when Inventor insists on selecting the construction lines laying behind the segment that you are clicking or tells you that a coincident constraint is required and then... “failed to make coincident constraint”.
Multiple embosses onto the same non-planar surface will fail.  Cylindrical components should be capable of being inserted into holes that pass through non-planar surfaces, as any infant can figure out how to do (hint: in addition to looking for a circular hole on a planar surface, look for any concave cylindrical surface).  Also, the contacts (other than bonded) often do not prevent chunks of steel from passing straight through each other under the smallest of loads, as if everything in Inventor land is made from neutrinos.  Error messages often do not help much with trouble-shooting when lofts, sweeps, extrusions, etc. go wrong (how about showing the resulting problem?).  I know that the Inventor community has found work-arounds for many of these problems, but if Autodesk wants to create a better product, I think they should focus on addressing some of these user-friendliness / productivity issues rather than moving things around again.
Message 9 of 15
MariaManuela
Hi
The Design Assistante also deserved an improved and intuitive interface and some news features. Never changes year after year....
He's ugly.
Asidek Consultant Specialist
www.asidek.es
Message 10 of 15
SBix26
in reply to: MariaManuela
I agree!!
MariaManuela wrote:
Hi
He's ugly.
Message 11 of 15
WAYNE_HOUWD
I just came across this topic. Seems this reply is late for this pointed survey- but I would say it will never be late for Inventor to improve...
In Inventor 2012, there is a pop-up menu when we right click the mouse. The annoyance is that the pop-up menu will not float smartly!
Take an example- usually "Find in Browser" is always blocked from the screen because it is in the bottom area of the pop-up. How did I deal with it? Moved the assembly up and right clicked the mouse again! It is very annoying!
If Inventor can make the pop-up menu floating automatically, that will be sweet!
Another, comparing to "Solidworks Hole-Wizard function", Inventor looks like far behind on this hole feature. That feature can give us the advantage that we can apply Library Parts easily and very convenient, especially for the irregular hole-layouts. Unfortunately, Inventor doesn't have this application. If Inventor can work out some kind of similar feature, I would say Inventor will be much more lovely!
Hope these two comments are never too late for Inventor to Improve!
Thanks.
Message 12 of 15
prusas
in reply to: WAYNE_HOUWD
It can not be so irresponsible switch the program interface. For many years there working habits are hard to change and hindering performance. Interface to be without any embellishment, and minimized.
Windows 7 64 bit
Intel® Core™ i7 CPU X 990 @ 3,9; RAM 12Gb x 1600
OCZ-Vertex 4 SSD (119.24GB)
Asus NVIDIA GeForce GTX 580; PLE2607WS 1920x1200
Message 13 of 15
dick_upton
PLEASE DISBAND THIS TASK FORCE AND DEVOTE THE LIMITED RESOURCES TO RESOLVING REAL ISSUES.
 YOU HAVE ALREADY WASTED TOO MUCH TIME AND RESOURCES WITH THE INTERFACE. THE SELECT OTHER CHANGES ARE NOT AN IMPROVEMENT. THE HELP FILE CHANGES ARE NOT AN IMPROVEMENT. THE HUD'S ON THE CONTEXT MENUS ONLY SERVE TO SLOW THE USER DOWN.
STOP DIDDLING WITH THE INTERFACE AND GET BACK TO WHAT'S IMPORTANT.
Message 14 of 15
dan_inv09
in reply to: dick_upton
new icons!
Message 15 of 15
MariaManuela
in reply to: dan_inv09
Hi people,
I think some are realizing the questionnaire incorrectly.
Everyone knows that the Inventor need other things besides a washing face....but that will come in other questionnaires, this is only about interface. Period. 🙂
So, enjoy talking about this, which certainly has things to improve. Not only the inventor but all other external Inventor tools (Design Assistant, pack and go, ..... Task Scheduler) can improve graphically (when using the design assistant almost cut my wrists) 😞
So...in my opinion improving the interface or simple talk about this does not invalidate add new features.
www.asidek.es
