I am using Inventor 2012. Is there any way to create my own color scheme or edit the current one? I am using Winter Night and I like that one. However, when I select lines in sketch, the selected color is almost the same as the sketch color and it makes it hard to see which lines I have selected.
I want the selected color to be different. Any way to change this permanently without picking a different color scheme?
Solved by mcgyvr. Go to Solution.
I changed the selection color for Drafting to a bright Pink. However it is still Green. Why am I not getting Pink? They only time I get Pink is when I Retrieve dimensions and select the ones I need. Otherwise I get green.
