Inventor Forum
Use of getChoice = Choose(index, "first", "second", "third")
2 REPLIES 2
701 Views, 2 Replies
I  have a query regarding one i-Logic function.
In i-Logic, there is a function called getChoice = Choose(index, "first", "second", "third")
Please find attached snapshot of i-Logic browser for your reference.
What is the use of this function and how to use the same.
I am unable to figure it out, could you please share any simple example using this function.
Please help me out on same.
2 REPLIES 2
VdVeek
The "choose" option checks which MultiValue Parameter is chosen.
If you create a Parameter with the name: ParamName and add some values (example: 1, 2, 3) to it and choose one, let's say option 2.
When you create a rule with the next lines
getChoice = Choose(ParamName, "first", "second", "third")
MessageBox.Show("Chosen Value : " & getChoice, "Title")
and run this rule it shows "Chosen Value : second"
So you don't see the value of ParamName but the coresponding string.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
WCrihfield
in reply to: VdVeek
So...:this function can only be used similarly to IndexOf(ParamName), only it returns string type values instead of Integer type values?
Wesley Crihfield
