Inventor Forum
Use filename as parameter
16 REPLIES 16
Message 1 of 17
EmpireBuff
1935 Views, 16 Replies
Is there a way to use the filename to drive the parameters of the file?
Example: I have a cube that is called 4x4x4.ipt its dimensions d0,d1,d2 are 4,4,4 respectively. I want to rename it to 4x4x6.ipt and have the dimensions d0,d1,d2 resize to 4,4,6.
16 REPLIES 16
Message 2 of 17
in reply to: EmpireBuff
Option 1: Through VB code read the filename and parse it and then set it to the parameters d0,d1,d2 and update. autodesk.inventor.customization group could provide more help here.
Option 2: You might be knowing this already you can create an iPart with d0,d1,d2 as columns and then create keys for them and then see if that works out. You could add rows for as many variations as possible. This does create files though.
shekar
Message 3 of 17
Free of charge 😉
T. Ham
Mechanical Engineer
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Message 4 of 17
option 3 get a copy of yippee pro.
use the parameters to drive the filename
Message 5 of 17
The only problem...he wants it the other-way-around 🙂
T. Ham
Mechanical Engineer
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 6 of 17
some say tomato, some say tomato, wait that doesnt work here...
i really should think about learning some code, nice work
Message 7 of 17
For those of you who are curious how Teun did it he used Option 1. When you open the IPT file attached by Teun go to Tools, Macro, Visual Basic Editor to see the script that will be run when the file is opened. Nice job Teun. Thanks.
shekar
Message 8 of 17
One remark: the macro is embedded in the IPT. This can cause problems when
you have a lot of IPTs open at the same time (it's a VBA limitation, so you
can blame Microsoft for it)
An Add-in would solve that problem, but my example is just to show that it
can be done!
Cheers,
T. Ham
Mechanical Engineer
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 9 of 17
EmpireBuff
You have all been very helpful, especially you Teun, I was trying to do this for a while now and only found out about this discussion group yesterday. My first experience has been very good !!!!
Cheers !!!
Message 10 of 17
No problem!
T. Ham
Mechanical Engineer
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 11 of 17
UpRising
I was wondering what is the parameter for file name if it exist?
I did try: =<file name> and it's not working...
thank you
Message 12 of 17
UpRising
in reply to: UpRising
so there is no way to do that?
Message 13 of 17
dfitting
Tuen,
This is amazing, it is exactly what I am looking for.
The only problem I am having is that when I rename the file in windows explorer and then open the part, the VBA isnt running. I am having to go into the Macros and select it and run it that way.
Im using Inventor 2014. Is there a setting I need to enable for it to run the code when the ipt is opened?
Message 14 of 17
Hi dfitting,
I'm not sure Tuen is still present on this forum, but here is the code from his example file, in iLogic format. You can create a rule in your part and paste in this code, and then set the ilogic "After you open a document" event trigger to run the rule when the file is opened.
'this rule expects a part file named something such as 1x2x5.ipt
'define active document
Dim oPartDoc As PartDocument
 oPartDoc = ThisApplication.ActiveDocument
'look at the parameters
Dim oParameters As Parameters
oParameters = oPartDoc.ComponentDefinition.Parameters
'define the parameters
Dim oParameter(3) As Parameter
oParameter(0) = oParameters.ModelParameters("d0") 'Length
oParameter(1) = oParameters.ModelParameters("d1") 'Width
oParameter(2) = oParameters.ModelParameters("d2") 'Thickness
'look at the full file name of the part
Dim sFullFileName As String
sFullFileName = oPartDoc.FullFileName
'format the file name
Dim sFileName As String
sFileName = Right(sFullFileName, Len(sFullFileName) - InStrRev(sFullFileName, "\"))
sFileName = Left(sFileName, Len(sFileName) - 4)
'split the file name using x as the sperator
'and set it to an array
Dim Values() As String
Values = Split(sFileName, "x")
'parse the array and set the parameters
Dim i As Integer
For i = 0 To 2
    oParameter(i).Expression = Values(i)
Next i
'update the model
oPartDoc.Update
'zoom all
ThisApplication.ActiveView.Fit
Creating a Basic iLogic Rule with an Event Trigger
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
Work with event triggers in iLogic
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-DA0F4988-AE08-4791-83E5-F9D41B82D4F6...
I hope this helps.
Curtis
Message 15 of 17
Thanks a bunch Curtis, I actually go it working with a simple ilogic rule that calls the vba, I am going to use this instead though so that its not using ilogic to call the vba, might get messy down the road.
A quick question, if I wanted to name my file 50x25x2 - Earthen Berm or maybe a client name, how would I get the ilogic to stop reading the file name once it gets to the -
Message 16 of 17
Hi dfitting,
This rule should do it. I added a couple of new things to set the Part Number, Description, and reset the browser, etc.
'define seperators as capital X, lower case x,  and dash
Dim Separators() As Char = {"X"c,"x"c, "-"c}
'define and set array to hold results of split filename
Values  = sFileName.Split(Separators)
Dim i As Integer
'look at first three Values in the array (0 ,1, 2)
For i = 0 To 2
	'set parameter values to array values
Next i
'set Part Number
iProperties.Value("Project", "Part Number") = Values(0) & "x" & Values(1) & "x" & Values(2)
'set Description
iProperties.Value("Project", "Description") = Values(0) & "x" & Values(1) & "x" & Values(2) & "-" & Values(3)
'set Description (alternative method)
'iProperties.Value("Project", "Description") = sFileName
'reset browser name (in case someone has overidden it in the past)
ThisDoc.Document.DisplayName = ""
'update the model
oPartDoc.Update
'zoom all
 I hope this helps.
Curtis
Message 17 of 17
Thank you sir for all your help!
Works perfectly, had to remove the little c's that were in this line:
Dim Separators() As Char = {"X","x", "-"}
