Inventor Forum
Use cases for multiple standards
12 REPLIES 12
Message 1 of 13
528 Views, 12 Replies
Let me preface this by asking that we keep this simple...
Who among you utilize multiple standards in one drawing?
Can you provide some detailed scenarios on why you need to use multiple
standards?
Feedback is greatly appreciated. Thanks.
Andrew Faix
Product Designer - Inventor Drawing Manager
autodesk
12 REPLIES 12
Message 2 of 13
One example:
Anyone who has multiple customers who demand drawings to fit their specific
standards.
While this could be done in multiple templates, it is often simpler to
maintain one template and have multiple standards.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Andrew Faix (Autodesk)" wrote in message
news:03E13C79713EFFA05B4689E1E198FFF8@in.WebX.maYIadrTaRb...
> standards?
> Andrew Faix
> autodesk
Message 3 of 13
Thank you...
I would like to see different types Parts lists (columns) per sheet.
But to be able to map an entire standard per sheet (or even view) would be
awesome. But could we call it "Standard" anymore? Haha!
A
> standards?
> Andrew Faix
> autodesk
Message 4 of 13
Sean beat me to it. Multiple customers is the reason Iwould give as well.
Cory McConnell
BJ pipeline Inspection
Message 5 of 13
Multiple standards in one drawing would allow you have section line
arrows and detail arrows different sizes to better fit the area of
interest. The view labels could also be adjusted to suit the available
space.
> standards?
> Andrew Faix
> autodesk
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
Message 6 of 13
Autodesk could make it easier / more intuitive to copy standards from one
drawing to another... and also update a drawings standards (and symbols) to
match the latest revision of a template. That would solve a large number of
issues...
Tim W.
Message 7 of 13
Hey Andrew,
I use multiple standards for different parts list definitions.
> standards?
> Andrew Faix
> autodesk
Message 8 of 13
We're a German owned company in the states designing and implementing waste
water treatment equipment.
Our German counterparts use a different standard than we do here in the
states. All of our projects are rather large and we will mix and match our
standards depending on the equipment used in the project (German, ours, or a
mix of both.). We also place our projects all of the world and we will have
to use different standards depending who and how our equipment is being
installed.
Our projects are rather large in size, and on a drawing we can range from a
large assembly 200' long, to a piece part 1" long. Our line scales always
get messed up and we have to manually set the scale for hidden, center, and
other objects.
Message 9 of 13
I see the use of a drawing standard very useful, however most of our clients
make up their own variants (thinking they conform) with parts of the ANSI,
AS and ISO used. e.g. the way a detail circle is annotated in ANSI is widely
used. 3rd angle is most popular, we use "." in place of the ISO ",",
centrlines vary greatly from one company to another etc.
Most that i know create their own standard based on ISO and then modify it
to suit. When they don't like the way the standard works they change to ANSI
and carry on. A bit of a pain.
Hope this helps.
Matthew
CADPRO Systems
> standards?
> Andrew Faix
> autodesk
Message 10 of 13
It would be helpful if standards could be copied with the organizer.
Message 11 of 13
Excellent feedback, thanks everyone.
More comments are welcome.
> standards?
> Andrew Faix
> autodesk
Message 12 of 13
Multiple suppliers (Taiwan, China, Switzerland)
Multiple production plants (Canada, China)
OEM Customers require things done 'their way"
Paul Houlker
Rimex Supply Ltd
www.rimex.com
Message 13 of 13
xavierl
I work in SI metric and mostly use the ISO titleblock. occasionally I need imperial units for a customer from the usa and then use alternate units in dim styles.
The big clients like Natianal Roads Authority, the City Council , the Navy etc... insist on their own drawing titleblock and standards, even down to specifying the text size and font.
the small clients dont know the difference so they just get the straight ISO titleblock.
I definitely dont want to convert SI drawings to Imperial by scaling, so multiple units and styles is a must
regards
frans x liebenberg
