Hi there,
a customer has a title block with a revision table ( standard vault revision table) add on top of it.
If you change the sheet size the revision table remains his position.
If found the way to reposition the table with a ilogic rule.:
'point afstand in cm
PointX=(ActiveSheet.Width/10)-13
PointY=5.5
'punt vanaf rechtonder gemeten in cm
DimoPointAsPoint2d
oPoint=ThisApplication.TransientGeometry.Createpoint2d(PointX,PointY)
'her positioneel revisiontable
ActiveSheet.Sheet.RevisionTables.Item(1).Position=oPoint
InventorVb.DocumentUpdate()
This is working perfectly.
But now the challange how to trigger this rule to run if you change the sheet size?
if tried:
trigger=Activesheet.size
or
to create a userparameter and added this line in my rule : Size=ActiveSheet.size, normaly is you change parameters it triggers the rule to rule.
but both way didn't work.
Can event triggers from the API be used? Do i need the "Onchange" event?
Can anyone give an example for a ilogic rule?
Kind regards,
