Inventor Forum
Use a parameter from sub-assy
3 REPLIES 3
146 Views, 3 Replies
Okay...
I've got a large assembly, and one of the sub's is a rack-and-pinion
drive thingy. As I'm building, I drive the constraint for the rack to
move my big assy around. I want to add a constraint in the big assy
that references the value of the driven parameter in the sub. How can I
do this? My first attempts have me doing this:
max(Drive/d13-2.25-0.75;-0.75)
I place that in the constraint 'offset' for the parameter I want to
change. That's how I want it to behave. But, I can't get past the
"Drive/d13" part. That's not supposed to be a division, that's the name
I get for the parameter "drive" when I pause my mouse over it in the
browser.
Any ideas?
-Jason
3 REPLIES 3
Unfortunately you cannot access a sub's parameters in IV at this time.
You can make the sub adaptive them constrain the rack to the top level and
drive it this way.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Jason M" wrote in message
news:8E9F9D32DF6B275168F84D1CCB321BD2@in.WebX.maYIadrTaRb...
> Okay...
> browser.
> Any ideas?
> -Jason
Thanks... I'll stop trying for now.
-Jason
> drive it this way.
> Sean Dotson, PE
>>Okay...
>>browser.
>>Any ideas?
>>-Jason
jorgen
I've had some succes using this methode:
1-Make a sketch in your top assembly, referencing geometry in sub-assys.
2- Make a driven dimension to "simulate" the dimension you wish (not always possible)
3- You now have the dimension accessible in the top assy.
Not sure if this helps in your case, but good luck.
Jorgen
