Inventor Forum
Upper case in Part List
4 REPLIES 4
luiww
7469 Views, 4 Replies
I wonder if one could change the characters in the part list to upper case when the file name is in lower case.
4 REPLIES 4
mpatchus
in reply to: luiww
This WILL NOT work for the filesnames, but will for other iproperties such as description, comments, etc.
  1. Open the BOM for the assembly
  2. Highlight the entries you wish to have upper case
  3. RMB and select CAPITALIZE
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
luiww
in reply to: luiww
How do I open the BOM for assembly?  Is this under the assembly annotate tab or using the design manager?  I tried both and not able to locate it.
pcrawley
in reply to: luiww
Just mouse-over the parts list in the drawing so it highlights - right-click - Select Bill Of Material.
You can select everything in the BOM editor (click in top-left corner and drag down and right) - then right-click and select "Capitalise".
As the previous post says, you can't capitalise filename (or anything else that is grey).  These typically include library and CC parts.
Peter
IgorMir
in reply to: luiww
Just like that. Please see the attached.
Igor.
Web: www.meqc.com.au
