I wonder if one could change the characters in the part list to upper case when the file name is in lower case.
Solved by IgorMir. Go to Solution.
This WILL NOT work for the filesnames, but will for other iproperties such as description, comments, etc.
How do I open the BOM for assembly? Is this under the assembly annotate tab or using the design manager? I tried both and not able to locate it.
Just mouse-over the parts list in the drawing so it highlights - right-click - Select Bill Of Material.
You can select everything in the BOM editor (click in top-left corner and drag down and right) - then right-click and select "Capitalise".
As the previous post says, you can't capitalise filename (or anything else that is grey). These typically include library and CC parts.
