Not sure if this is the correct forum, so I have posted here and in the Vault group.. In the previous version of Inventor (2012) have been using ADMS 2012 to serve Content Center files to several users, but yesterday updated them to IV2013 and got to the step of updating the Content server. How do you do this now? Is there an equivalent, such as ADMS 2013 or do you use Vault Server? Product Design Suite only has Vault Basic (Client). From memory last version ADMS 2012 was a download.
Solved by DarrenP. Go to Solution.
Solved by -niels-. Go to Solution.
Check under the "Tools" section of the installer, the ADMS 2013 should be there though i'm not sure of it's name... but it's still called ADMS when installed.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
for 2013 product design suite now comes with the adms console
its not a separate download anymore
on the intall setup screen instead of choosing install products you choose the tools & utilities button
DarrenP
