Does Autodesk Inventor 2014 handle upgrade of lower versions?
Are you asking if you can upgrade the program, or have to uninstall and install a new one?
Or are you asking if it handles old files?
yes new versions of Inventor will prompt you to "migrate" files created in older versions.
If thats what you are asking
Hi all,
I want to uninstall lower version and keep only higher version.
I checked this scenario and find higher version doesnot support upgrade of lower version instead both coexist.
We do not want lower version to exist on machine. Please respond ASAP.
Another query : does autodesk require compulsory REBOOT after uninstallation/
Can we manually uninstall lower version and then install higher version without REBOOT in between.
You will have to uninstall lower versions.
It reboots for the sake of the registry database. It is prone to make errors during an installation if you don't reboot.
