Inventor Forum
Updating threaded hole
3 REPLIES 3
38graham97
103 Views, 3 Replies
When changing the size of an iPart, the part is updating correctly, except for the treaded hole. If I select edit feature, then the hole will update to the correct thread. Any suggestions as to why?
3 REPLIES 3
in reply to: 38graham97
Is that threaded hole called out in the table with a new value for each
variation?
> Thanks
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
38graham97
Yes, there are four different size parts, the smallest has a 0-80 thread, the other three have 2-64 threads.
Does the table have at least three columns for defining the threads, if
not, you might want to review the tutorial for threaded iParts at
www.sdotson.com.
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
