I have crated a drawing of the part. Now I must be updating the drawing template. How I can update the drawing templates to old drawings?
-Juha
open a new template
save copy as template
save styles to library
open old drawings
click update styles
replace any new templates(if u have different template name)
or use Drawings Resource Transfer Wizard
Which is in Tools
Now I changed the Title block. How I can update its? I tried to save to the style library but there is not saving anything? So blocks is not in style library?
you can cut and paste the title block between drawings, when pasting it asked if you want to replace the existing (if the title block is the same name) or put a copy in. Then you can just save the new as a template file.
forgot to say, right click and select copy from the drawing resources/title block/[title block name] in the drawing enviroment as you cant select the title block directly from the drawing
As in the post earlier in this thread, use the Drawing resource transfer tool. You can select to copy only the title block to the other target drawings.
Cheers
Is there a possibility to additionally copy the ilogic rules from the template into multiple drawings?
Thank you for your answer.
This posting is 5 years old you should've creating your own posting..
But to answer your question.. Yes by using the Inventor Code Injector.
Mark Lancaster
& Autodesk Services MarketPlace Provider
If you have 2018 Update 1 (2018.1) you can also use an external rule and set a trigger from the event triggers to apply to "all drawings"
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-B14A47F4-81D2-4627-A973-2BC7F790DF89
