I am trying to create an iLogic (or VB) rule to update an active drawing title blocks from our Template File.
Is this possible?
I don't want to use any of the external software (Transfer Wizard etc), we just need a simple rule that will update the title blocks when we need to.
Any help would be greatly appreciated.
What exactly are you trying to update? iProperties?
I am not following what you are trying to accomplish.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
This should be possible in iLogic.
You can get things from and insert things into a drawing with iLogic, so as long as your templates do not move, then a rule should be able to pull updated items and params from them.
The time to develop the rule may outweigh using the task scheduler to automatically update files for you.
T.S.
We are trying to update the Title Blocks in the Drawing Resources.
We currently do this by opening up the Template file, selecting the Title blocks in the drawing resources and copying them..
Then goping to the active docuemtn and pasting the new title blocks into the drawing resources and replace the old ones with the new ones.
Hope this makes sense?
Many thanks
Use the Drawing Resource Transfer Wizard (Start menu -> Programs -> Autodesk -> Autodesk Inventor [version] -> Tools -> Drawing Resource Transfer Wizard).
It updates selected "target" drawings' Drawing Resource folders using your new template drawing as the "source" file. This is how I push a change in our drawing borders across all the files.
Read more here http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0684-Collabor684/0725-Tools725/0...
Yeah, that makes sense. As you make changes to your titleblocks, you want to be able to grandfather those changes into drawings that have already used the old TB's through iLogic.
Yes, this should be able to be done. I am not an iLogic guru, so I can't help you with that. Sorry.
Have you check this free addin.
Automatic update Drawing Resources
http://www.mcadforums.com/forums/viewtopic.php?f=34&t=8018
Rene J
"I don't want to use any of the external software (Transfer Wizard etc), we just need a simple rule that will update the title blocks when we need to."
I know you stated the above, what is the main reasoning for this?
If it is time, then the time it takes to update 1 drawing would be about the time it takes to wizard all the changes over to all the drawings.
Also I believe you can schedule updates to occur off-hours, if you are running a network that is always up.
T.S.
Yea I'm not understanding the reasoning for the OP not wanting to use the Wizard as it saves a ton of time. The DRTW is also not what I would consider "External Software" since it runs IV in the background when you use the utility.
Rene, never knew of that free add-in. I have always wanted to make my template become a true "master file" for which all changes would populate to drawings down the road. I will have to give that add-in a try! Thanks for posting it.
In this thread link I believe there is a rule that might do what you are looking to do.
Check it out.
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-help-needed/td-p/3556718
Thanks to all for your comments.
As per my original thread, we have no interest in using the drawing transfer wizard. Yes, it may be good at what it does, but we don't want to use it.
All we want to be able to do is update our title blocks (From our Template File - This does not move) from a simple click in Inventor using I logic.
Ref the Add-in, we don't want to use this as it would mean installing it on each machine and then setting it up.
Thank you for posting the links to the threads about updating the title blocks. I have already tried these and they work, but just for the active sheet not the whole drawing.
We need to be able to update ALL the title blocks in the Drawing, not the Active Sheet.
When you manually paste the title blocks into the Drawing Resources it updates all the sheets.
Thanks again you for support and any other assistance would be great.
I have some normal VBA code which will copy and replace a titleblock from a template file. I'm not familar with iLogic but you should be able to use this as a base or for ideas.
This function is made to replace a specific assembly or detail title block but could be changed to be more general.
Function Uptitle() Dim odrawdoc As DrawingDocument Dim oTemplate As DrawingDocument Dim oSourceTitleBlockDef As TitleBlockDefinition Dim oNewTitleBlockDef As TitleBlockDefinition Dim oSheet As Sheet Set odrawdoc = ThisApplication.ActiveDocument Set oSheet = odrawdoc.ActiveSheet If (oSheet.TitleBlock.name = "DPMS_ASSY") Then fname = "D_ASSY.idw" ElseIf (oSheet.TitleBlock.name = "TOLERANCE") Then fname = "D_DET.idw" Else: MsgBox "This drawing has an unknown title block" Exit Function End If Set oTemplate = ThisApplication.Documents.Open(ThisApplication.FileOptions.TemplatesPath & fname, False) Set oSourceTitleBlockDef = oTemplate.ActiveSheet.TitleBlock.Definition Set oNewTitleBlockDef = oSourceTitleBlockDef.CopyTo(odrawdoc, True) On Error GoTo ErrHandler: For Each oSheet In odrawdoc.Sheets 'oSheet.Activate if error occurs oSheet.TitleBlock.Delete Call oSheet.AddTitleBlock(oNewTitleBlockDef) Next oTemplate.Close Exit Function ErrHandler: oSheet.Activate Resume End Function
Thank you to all who have posted and helped with this issue.
Sorry it has taken me so long to get back with our solution..
Attached is the code I have managed to get to work (with a single click of a button on an Inventor iLogic Form) to update the title blocks in a drawing from our drawing template.
This is the basic process of the code:
Remember the Active Sheet Name & the Title Block visible.
Delete ALL the Title Blocks from each and every sheet.
Delete the Title Blocks from the Drawing Resources
Get the Title Blocks from the Template File
Insert the Title Block that was on the active sheet on all the sheets.
Re-Select the Active sheet at the start of the code.
The things I have found out as I have been doing it as as follows:
The Names of Each Title Block MUST be the Same for the Template File and the Files being inserted into.
This is to ensure that the title block on the active sheet when the button is plressed is inserted into the drawing at the end.
I used the full path for our template file and NOT referanced a Drive Letter.
The Screen flickers alot when this is being updated as the Code activates each sheet.
If you run this code from a rule or a NON-Modial Form, it will expand every sheet in the browser to show the Title Block Being inserted.
However, If you run the rule from a button on a Modial Form, it will not modify the expanded sheets in the browser.
I know this is not a very pretty bit of code, but it works for us and is a single click to update the title blocks as and when we need to.
If anyone has any comment or improvements on the code (Getting rid of the screen flickering would be great) plesae let me know.
Thanks again.
Clive.
This is exactly what I am looking for with one small caveat. IN order for it to work, I have to manually delete all sheet formats using those titleblocks first.
Does anyone have a fragment of iLogic code that will delete all sheet formats so that I can append this one?
Thanks in advance,
Scott
Hi sco.smith,
Here is a bit of code taken from my own custom Replace Title Block From Template rule. I think it should work for you, but I didn't test it, I just copy/pasted from what I had. Post back it doesn't work and I'll have a look to see what I left out/inlcluded, that is needed/not needed.
I hope this helps.
Curtis
If oCurrentPane = "Vault" Then ThisApplication.ActiveDocument.BrowserPanes.Item("Model").Activate End If 'delete sheet formats Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveEditDocument Dim oPane As BrowserPane oPane = oDoc.BrowserPanes.ActivePane Dim oDocNode As BrowserNode oDocNode = oPane.TopNode Dim oDrawingResourceNode As BrowserNode oDrawingResourceNode = oDocNode.BrowserNodes.Item("Drawing Resources") Dim oSheetFormatsNode As BrowserNode oSheetFormatsNode = oDrawingResourceNode.BrowserNodes.Item("Sheet Formats") Dim oNode As BrowserNode For Each oNode In oSheetFormatsNode.BrowserNodes'oDocNode.BrowserNodes ' If the node is visible and expanded, collapse it. If oNode.Visible = True And oNode.Expanded = False Then oNode.Expanded = True End If Next Dim oSheetFormatNode As BrowserNode For Each oSheetFormatNode In oSheetFormatsNode.BrowserNodes ' Select the node in the browser. oSheetFormatNode.DoSelect ' Execute the delete command. ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute Next
This works great, but my issue is that I have the same name for title block.
I think what I'm looking for is to replace. is there a code for that?
and I also like to replace the border.
Joel
Here is my code I use:
Here is the main rule "Drawing Border and Title Block Update". I will also include the following External rules used in the code.
- "New Border Rule"
- "Border Deletion
SyntaxEditor Code Snippet
Sub Main() iLogicVb.RunExternalRule("NEW BORDER RULE") ActiveSheet = ThisDrawing.Sheet("Sheet:1") Dim N As Integer 'TOTAL NUMBER OF SHEETS Dim X As Integer 'SHEET NUMBER USED FOR DO LOOP COUNTER '---------------------COUNT THE TOTAL NUMBER OF SHEETS Dim oDrawing As DrawingDocument oDrawing = ThisApplication.ActiveDocument Dim osheet As Sheet i = 0 For Each osheet In oDrawing.Sheets If osheet.ExcludeFromCount = True Then i = i + 1 Else End If Next '---------------------REMOVE EXCLUDED SHEET FROM THE TOTAL SHEET COUNT oMySheetCount = oDrawing.Sheets.Count - i N = oMySheetCount X = 1 '---------------------REMOVE THE EXCLUDED SHEET FROM THE TOTAL SHEET COUNT oMySheetCount = oDrawing.Sheets.Count - i N = oMySheetCount X = 2 'Check if the document is drawing If ThisApplication.ActiveDocument Is Nothing Or ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then MsgBox ("Please open a Drawing to work on.") Exit Sub End If Dim oDrawingDoc As Inventor.DrawingDocument: oDrawingDoc = ThisApplication.ActiveDocument Dim SheetNumber As Integer 'TITLEBLOCK result = MessageBox.Show("Do You wish to Insert new Title block?", "Insert Title block", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If result = "6" Then 'Clear out the old Titleblocks For SheetNumber = 1 To 1 ActiveSheet = ThisDrawing.Sheet("Sheet:1") If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then oDrawingDoc.ActiveSheet.TitleBlock.Delete End If Next ' ActiveSheet = ThisDrawing.Sheet("Sheet") ' If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then' oDrawingDoc.ActiveSheet.TitleBlock.Delete' End If 'Delete the previous title blocks as the API does not support replacing Sheet Formats. DeleteTitleBlocks (oDrawingDoc) 'CALLING SUBROUTINE 'reference template ThisDrawing.ResourceFileName = "\\FSE-VAULTEX\FSE-Standards\Templates\Test Area - Do Not Use\FSE.dwg" ThisDrawing.KeepExtraResources = False ActiveSheet = ThisDrawing.Sheet("Sheet:1") ActiveSheet.TitleBlock = "FSE PRIMARY" End If '---------------------DO LOOP TO CHANGE SHEETS 2 AND ABOVE If N > 1 Then Do While X <= N ActiveSheet = ThisDrawing.Sheet("Sheet:"&X) ActiveSheet.TitleBlock = "FSE SECONDARY" X = X+1 Loop End If X = 2 N = oMySheetCount ActiveSheet = ThisDrawing.Sheet("Sheet:1") '---------------------ZOOM ALL ThisApplication.ActiveView.Fit '---------------------UPDATE ALL RuleParametersOutput() InventorVb.DocumentUpdate() End Sub 'subroutine Sub DeleteTitleBlocks(oActiveDoc As Inventor.DrawingDocument) 'Iterate through the collection deleting any titleblocks that are not referenced by the drawing object Dim oTitle As TitleBlockDefinition For Each oTitle In oActiveDoc.TitleBlockDefinitions If oTitle.IsReferenced = False Then oTitle.Delete End If Next End Sub
"New Border rule"
resu1t = MessageBox.Show("Do You wish to replace the borders?", "Replace Borders", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If resu1t = "6" Then Dim N As Integer 'TOTAL NUMBER OF SHEETS Dim X As Integer 'SHEET NUMBER USED FOR DO LOOP COUNTER '---------------------COUNT THE TOTAL NUMBER OF SHEETS Dim oDrawing As DrawingDocument oDrawing = ThisApplication.ActiveDocument Dim osheet As Sheet i = 0 For Each osheet In oDrawing.Sheets If osheet.ExcludeFromCount = True Then i = i + 1 Else End If Next '---------------------REMOVE EXCLUDED SHEET FROM THE TOTAL SHEET COUNT oMySheetCount = oDrawing.Sheets.Count - i N = oMySheetCount X = 1 Do While X <= N ActiveSheet = ThisDrawing.Sheet("Sheet:"&X) '-------------THIS RULE DELETES THE SHEET BORDER ON THE ACTIVE SHEET iLogicVb.RunExternalRule("BORDER DELETION") X = X+1 Loop X = 1 ThisDrawing.ResourceFileName = "\\FSE-VAULTEX\FSE-Standards\Templates\Test Area - Do Not Use\FSE.dwg" ThisDrawing.KeepExtraResources = True ActiveSheet.Border = "FSE - A1" ActiveSheet.Border = "FSE - A0" iLogicVb.RunExternalRule("BORDER DELETION") End If ActiveSheet = ThisDrawing.Sheet("Sheet:1") '---------------------ZOOM ALL ThisApplication.ActiveView.Fit '---------------------UPDATE ALL iLogicVb.RunExternalRule("iProperties - Drawing") RuleParametersOutput() InventorVb.DocumentUpdate() ThisDoc.Save
"Border Deletion Rule"
'-------------THIS RULE DELETES THE SHEET BORDER ON THE ACTIVE SHEET Dim oDrawDocC As DrawingDocument = ThisApplication.ActiveDocument Dim oSheetC As Sheet = oDrawDocC.ActiveSheet Dim oBorderC As Border = oSheetC.Border oBorderC.Delete
