HEllo,
I'm trying to update the Custom properties of an .iam according to its file name
Public Sub Tagnr() 'update custom prop "TAGNR" 'update Custom Parameter "TAGNR" 'according to name iam : projectNr...space tagnr PROJNR TCI.01.10 Dim invDocs As Documents Set invDocs = ThisApplication.Documents Dim invDoc As Document Set invDoc = ThisApplication.ActiveDocument Dim oSel As SelectSet Set oSel = invDoc.SelectSet On Error Resume Next If aSel.Count <> 1 Then MsgBox ("Please select only one assy to tag..") Exit Sub End If Dim oCoc As ComponentOccurrence Set oCoc = oSel.Item(1) Dim oParentOcc As ComponentOccurrence Set oParentOcc = oCoc.ParentOccurrence Dim bText As String Dim aText As String bText = oCoc.Name aText = oCoc.Name Dim oPos As Long oPos = InStr(bText, " ") bText = (Right(bText, (Len(bText) - oPos))) oPos = InStr(bText, ":") bText = (Left(bText, oPos - 1)) Dim i As Long Dim j As Long Dim OcFound As ComponentOccurrence i = 1 For Each oOcc In oParentOcc.SubOccurrences 'Debug.Print (invDocs.Item(i).DisplayName) If parOc Is oCoc Then j = i Set OcFound = oParentOcc.Definition.Occurrences(j) 'Debug.Print ("found it") Exit For End If i = i + 1 Next 'Debug.Print ("--" & j) Dim selDoc As Document Dim oProps As PropertySet Dim oProp As Property Set selDoc = invDocs.Item(j) Set aProps = selDoc.PropertySets("inventor User Defined Properties") For Each oProp In oProps Select Case custProp.Name Case "TAGNR" oProp.Value = bText End Select Next End Sub
But I can't find the way to make the link between the document.iam and the occurrence in the main .iam
any help would be greatly appreciated
