Inventor Forum
update Custom property according to file name
0 REPLIES 0
Message 1 of 1
^_^clovis^_^
190 Views, 0 Replies
HEllo,
I'm trying to update the Custom properties of an .iam according to its file name
Public Sub Tagnr()
    'update custom prop "TAGNR"
    'update Custom Parameter "TAGNR"
    'according to name iam : projectNr...space tagnr PROJNR TCI.01.10
    Dim invDocs As Documents
    Set invDocs = ThisApplication.Documents
    Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    Dim oSel As SelectSet
    Set oSel = invDoc.SelectSet
    On Error Resume Next
    If aSel.Count <> 1 Then
        MsgBox ("Please select only one assy to tag..")
        Exit Sub
    End If
    Dim oCoc As ComponentOccurrence
    Set oCoc = oSel.Item(1)
    Dim oParentOcc As ComponentOccurrence
    Set oParentOcc = oCoc.ParentOccurrence
    Dim bText As String
    Dim aText As String
    bText = oCoc.Name
    aText = oCoc.Name
    Dim oPos As Long
    oPos = InStr(bText, " ")
    bText = (Right(bText, (Len(bText) - oPos)))
    oPos = InStr(bText, ":")
    bText = (Left(bText, oPos - 1))
    Dim i As Long
    Dim j As Long
    Dim OcFound As ComponentOccurrence
    i = 1
    For Each oOcc In oParentOcc.SubOccurrences
        'Debug.Print (invDocs.Item(i).DisplayName)
        If parOc Is oCoc Then
            j = i
            Set OcFound = oParentOcc.Definition.Occurrences(j)
            'Debug.Print ("found it")
            Exit For
        End If
        i = i + 1
    Next
    'Debug.Print ("--" & j)
    Dim selDoc As Document
    Dim oProps As PropertySet
    Dim oProp As Property
    Set selDoc = invDocs.Item(j)
    Set aProps = selDoc.PropertySets("inventor User Defined Properties")
    For Each oProp In oProps
        Select Case custProp.Name
        Case "TAGNR"
            oProp.Value = bText
        End Select
    Next
End Sub
 But I can't find the way to make the link between the document.iam and the occurrence in the main .iam
any help would be greatly appreciated
0 REPLIES 0
