In our continuing efforts to provide high quality products, Autodesk has released Update 3 for Inventor 2014 SP2 which addresses multiple issues (see readme file).
Please note that there is a Typo in the file name of the URL for the Update download, The file name should be INV18230.zip. This will be corrected today. You can download the file from here: INV18230
We thank all our customers who identified these issues and reported them to us. These reports give us the opportunity to improve the product and provide you with the best solution in mechanical design. We also thank you for your continued business and for feedback regarding the content of this update release.
Respectfully,
Autodesk Inventor Product Team
Solved by cwhetten. Go to Solution.
The first link above sends me to a page that says "Access denied" (see image below). Use the following link instead:
Using Firefox 33.1
Cameron Whetten
Inventor 2014
Just installed this on clientsand Job Processor machine. First files processed all look like this. Any ideas?
If I do an Update Locally (Vault) the files turn out as they are supposed too.
Oops. Made a mistake. The problem I mentioned is not with SP2 UPdate 3. It's with Hotfix INV18231.
Sure. What do you need? A defective DWF file or a part/assy data set or ???
The part/assy data set as well as the defective dwf file would be good.
Amanda
Hi David.
Yes, I have INV18230 installed prior to INV18231. I have removed 18231 from the job processor machine which has fixed the problem, but now I'm back to a previous problme that 18231 should have fixed.
18230 resulted in DWF files with correct dimensions and parts list but no views on the drawing and the graphic missing from the titleblock. 18231 read like it fixed these issues, and it dod slightly in that the views were present by were an odd clouur and linetype/thickness and all of the text was offset and the wrong size and font.
Autodesk Support Rep eventually rebuilt the Job Processor machine to Update 2 for SP2. Since then all DWF's are produced correctly.
