My Autodesk Application Manager shows me that on 11/5/14 there is an Update 1 to SP1 available, and I was able to install it.
However, the download section of the Autodesk Knowledge Network for Inventor does not list any INV19110 updates.
Whats UP? I'd like to have this downloaded for my archives.
Mark
Solved by david.harris. Go to Solution.
Solved by DarrenP. Go to Solution.
it does download the file from the application manager
if you go to the application manager settings> files tab>local files
this is where it gets downloaded to
all the updates will show up through the application manager first then appear on knowledge network at a later date
DarrenP
This Update is now live on the Autodesk Knowledge Network:
Update 1 for Inventor 2015 SP1
Best Regards,
David
Ok, but :
This is what i get ( attachment) after exporting to pdf using pdf translator thru macro:
Public Sub PublishPDF() ' Get the PDF translator Add-In. Dim PDFAddIn As TranslatorAddIn Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document Set oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext Set oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then ' Options for drawings... oOptions.Value("All_Color_AS_Black") = 0 'oOptions.Value("Remove_Line_Weights") = 0 'oOptions.Value("Vector_Resolution") = 400 'oOptions.Value("Sheet_Range") = kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Set the destination file name oDataMedium.FileName = "c:\temp\test.pdf" 'Publish document. Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End Sub
After installin sp1 is ok an so i did copy of dwfout, dwfOutUtils, dwfOutUI files from C:\Program Files\Autodesk\Inventor 2015\Bin directory and after installation of update 1 to sp1 i replaced them, right now it works just fine but you should know about that issue...
best regards
marcin otręba
