I have a basic problem with the unknown force - torque in Dynamic Simulation. I have designed a two joint inverted pendulum, I need to check the minimum motor torque it required to move 90 deg upwards. So I have made some manual calculation and input it on the joints as constant value for 4650 Nmm (it should be at 4618 Nmm by manual calculation), as result it works just as it should be. Now I have a problem with the unknown force, I could only obtain around 200 Nmm as minimum torque, and its not coming from the unknown force options hierarchy.
If I use the unknown force of torque in output grapher it will give me 0 Nmm, so this is my question. Is it due to my basic knowledge of using constrains or there is something wrong with the unknown force?? I have attached my drawing, feel free to open.
Solved by henderh. Go to Solution.
I get an error when extracting your files.
What program did you use to zip?
Hi Indrawibawa,
DS gives us 4599 N-mm as the maximum for Unknown Torque.
I re-defined the location of the Unknown torque to the circular edge of the motor snout that has the revolution joint and it worked. I've attached an assembly in the R2013 format.
Best regards, -Hugh
