Inventor General Discussion
Active Contributor
rms390
Message 1 of 6 (200 Views)
Unknown Error With a surface split.
200 Views, 5 Replies
10-26-2012 09:37 AM
Attached is a surface model with parameters which drives an assembly I have.  I was testing it by changing dimensions to see where failures in the main assembly occured.  It worked for a few changes so I saved it and checked it into vault.
The Split using the 70 Deg Plane (you will find them in the browser, Split 5 and Split 7) is where the problem occurs.  When I increase the outside diameter (i made it 147 in.), Spits 5 and 7 get moved up to the top half.
The same surface (named OUTER HOUSING SIDE) and its mirror are split on the XZ plane prior to the splits in question (5 and 7).
Could anyone tell me what exactly is happening?
JDMather
Message 2 of 6 (192 Views)
Re: Unknown Error With a surface split.
10-26-2012 10:10 AM in reply to: rms390
I didn't take a look at the problem you describe - but it looks to me like you are doing too much work.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Contributor
rms390
Message 3 of 6 (185 Views)
10-26-2012 10:38 AM in reply to: rms390
I rolled back my eop marker to where it is just the three surfaces and splits.  It does the same thing.
JDMather
Message 4 of 6 (164 Views)
10-26-2012 05:36 PM in reply to: rms390
Took a longer look at this - you are doing wayyyyyyyy too much work.
When you get it finished - attach the file(s) here and I'll show you how I would have done it.
Active Contributor
rms390
Message 5 of 6 (143 Views)
10-27-2012 06:52 PM in reply to: rms390
I finished it up on friday and it seems to be working now.  I appreciate the help and I will attach it on monday.
Active Contributor
rms390
Message 6 of 6 (105 Views)
10-29-2012 08:30 AM in reply to: rms390
here is the file
