"ohunome" <Am
href="mailto:cschmidt@fife.com">cschmidt@fife.com> wrote in message
href="news:f18d64a.-1@WebX.maYIadrTaRb">news:f18d64a.-1@WebX.maYIadrTaRb...
I the only one that is struggling with units in the parameters table. This
thing is impossible to understand and is not user friendly at all. Ive read
all about converting units and all that but I still struggle with this till
this day.
"ohunome" <I
href="news:f18d64a.1@WebX.maYIadrTaRb">news:f18d64a.1@WebX.maYIadrTaRb...
keep having problems when dividing. example 2 mm/1 in it keeps giving me a
unit mismatch.
"Dave Hoder" <
href="mailto:REMOVEdave.THESEhoderSPAM@idxseattleBLOCKING.comCAPS">REMOVEdave.THESEhoderSPAM@idxs...>
wrote in message
href="news:BBCB47944353852EF3D94A60E7454049@in.WebX.maYIadrTaRb">news:BBCB47944353852EF3D94A60E74......
HUH?
Dave Hoder
Product Design
Engineer
idX Seattle
href="http://www.idxcorporation.com">www.idxcorporation.com
"rllthomas" <I
href="mailto:rllthomas@attbi.com">rllthomas@attbi.com> wrote in message
href="news:f18d64a.8@WebX.maYIadrTaRb">news:f18d64a.8@WebX.maYIadrTaRb...
have no idea what you are saying. IV converts everything to cm internally and
does the math. (2mm / 1in) * 1in is certainly dividing by one inch and then
multiplying by 1 inch. If you need units of length after dividing length by
length then you need to multiply by length. I think we all agree with that. IV
will then spit the answer out in whatever the default units are OR what the
parameter is specified as so it is really all moot.
"Mark S. Klein" <
href="mailto:mklein@proxim.com">mklein@proxim.com> wrote in message
href="news:A87FEF4185D9D05CF05F2A35F3D92170@in.WebX.maYIadrTaRb">news:A87FEF4185D9D05CF05F2A35F3D......
Sean I'm just missing something I did type it in,
but just to check I added a dimension to another side of the rectangle I drew
at 22. My units are set to mm's. So now I have a box that is long on the 22
unit side and short on the other side at 2. I must of missed something as if I
understood you I was expecting the 2 unit length to be in inches when
finished, not mm's. Did I miss something here? It has been a bad day here so i
very well could have.
msk
I have to add my "HUH?" into this as I have a similar conversion headache.
In my case I'm trying to convert a length value to unitless so I can calculate material from inventory. I've dug around and see there's a command called ISOLATE in which I can put in a command line of ISOLATE(*LENGTH;in;ul) in the EQUATION field of my parameter dialog box and that is supposed to convert my variable named LENGTH from inches to unitless. Keying that in does not work with my Unit/Type flagged as UL or IN.
I have also attempted parts of this discussion using an equation of LENGTH * 1 ul but that also fails to work.
Can someone assist me in figureing how to make this conversion and save my keyboard & forehead?
That makes no sense at all - you are just multiplying by 1 - not canceling units?
Attach an example file here.
You will need to create a user parameter to take your length dimension and divide out the units.
What version of Inventor are you using?
Canceling units used to be covered in HS math classes. Sometimes it is a little trick in Inventor to figure out how to get the syntax just right for some problems.
(speeling even earlier) That was supposed to be Count rather than Counrt, but you get the idea.
