I have a solid which I need to miror as indicated by the selected plane.
The second page shows the result, which is quite unexpected: the two angle sections are completely missing and it fills in the space near the offset.
The only thing I can think of is that these angled sections were created with a split and for some reason I cannot select that feature in the mirror operation.
Is there a way to select all features?
Any other suggestions to make this work?
TIA
Robert
Solved by JDMather. Go to Solution.
In the Mirror dialog box there is an option to mirror the entire solid body.
@Anonymous wrote:
...relative to SOLIDIST?
SOLIDIST?
What program are you using?
Do you mean solidhist in AutoCAD?
