I've read on this blog that the max size for the Application options undo file size is 4095 for 64 bit. (Inventor 2011)
Anyone know the max size for 32 bit.
Steve
Solved by Dennis_Jeffrey. Go to Solution.
The UNDO buffer uses system memory, which on a 4GB 32 bit system is about 3.5GB Max. I'd leave it at default.
