I'm trying to understand how Inventor update assemblies when some of its components have been modified. For instance if I have an assembly OPENED and this assembly has a screw on a bracket with a constrain type of "mate" and for some reason the hole where the screw was constrained to, moves while the assembly is open, it what point does the assembly gets updated?
The reason I'm asking is because I'm currently using Inventor and Vault and if I change the location of a hole where a screw was constrained to, the assembly doesn't update the screw's location until I go and suppress and unsuppress the constrain. Is this a normal behavior in Inventor or it has to do with the fact that I'm using Vault?
In SolidWork if you have an assembly open and one of its components change the assembly updates immediately.
Solved by JDMather. Go to Solution.
Generally when I am working on a large assembly if a part is updated by the same computer all you have to do it slightly move the assembly or a part and then autodesk inventor will autocorrect the assembly for you because of the pre-existing constraints. However, if for instance you have a part that you edit that no longer fits the dimensions of the constraint, then the constraint will break itself and cause an error, in which you need to either delete the constraint or edit it (deleting is quicker in my opinion).
I personally haven't touched vault because I haven't needed to, and I hope this helps in some way.
Ok, so it looks like if the assembly is opened, Inventor will NOT update until you actually do some sort of interaction with the component that has changed or close and reopen the assemble. If this is correct, is there a way to force it to update without having to go and drag-move the compont that has changed?
Click the Update icon (just like SolidWorks) if it doesn't immediately update (looks like a lightning bolt in Inventor).
Wow, that sounds like a pain, imagine that you updated your part, than you open the assembly just to realize that you actually made the wrong adjustment, now close the assembly, make your changes, open the assemply again to verify the new changes, wow.
