Inventor Forum
Undeletable work axes
7 REPLIES 7
Message 1 of 8
mrattray
829 Views, 7 Replies
I can't seem to get rid of these no longer needed work axes. Any idea why?
(Don't wory about the missing file references, you shouldn't need them.)
Mike (not Matt) Rattray
7 REPLIES 7
Message 2 of 8
swhite
in reply to: mrattray
If it is the origin plane you can't delete it, but you can turn the visibility of them on or off by right-clicking on them and selecting visibility. if it is a user created plane then right-click it and select delete. The origin planes can not be deleted.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Message 3 of 8
japike
I don't know why they are there. The only way I could get rid of them was to pull the End of Folder marker above Pattern3, put in a new pattern and delete all features below EOP.
Peace,
Jeff
Inventor 2022
Message 4 of 8
japike
in reply to: japike
Looks like maybe you can just change the visibility of the work features too. Since they don't seem to exist in the browser you can't turn the visibility back on.
Peace,
Jeff
Inventor 2022
Message 5 of 8
cwhetten
in reply to: japike
It looks like they were created as part of the pattern.  Just edit the pattern and un-select the axis from participating in the pattern.  Then the only one you will have is the original, which you can delete if you need to.
-cwhetten
Please click "Accept as Solution" if this response answers your question.
Message 6 of 8
mrattray
in reply to: cwhetten
There isn't any original axis to deselect or delete.
Message 7 of 8
mrattray
in reply to: japike
This seems to work fine. I was assuming that they would come back when the number of slots changed, but this doesn't seem to be the case. Thanks!
Message 8 of 8
Yijiang.Cai
It is really interesting that how these work axis are created. However, you could use the attached iLogic rule to remove them.
Hope it helpful for you!
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
