I have started seeing this message "The following location(s) in your project are unavailable. If you continue opening the file, you may experience significantly slower performance than normal. Library C:\Vault\Library". I haven't changed anything that I'm aware of. Can someone tell me how to correct this?
Solved by scottmoyse. Go to Solution.
have you cleaned your workspace recently? That may have removed the folder, also i seem to remember there being a setting in vault somewhere, that may purge files from local workspaces over a certain age. I didn't think it deleted folder structures though.
I would say purely based on that message, that the folder doesn't exist anymore. Have you tried to browse to that location using windows explorer?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
I am having this same problem and the file the warning mentions has indeed been deleted. Do you know how I can get that folder back? It is the Libraries folder, I have tried just creating an empty folder in this location but that did not work. Any ideas?
