I am new to Inventor and need help.
I have draw in DWG the front view of a ship's frame. I've closed the loop in inventor and extruded the object but I am unable to sketch on most of the surface to complete the side view..??
I can only sketch on one section the upper and lower sections it won't allow me too.
The top should be offset to the right but I am unable to draw the sketch onto the fame.
Please help, Tim
Solved by cbenner. Go to Solution.
Welcome!
Well from the picture it looks like you're trying to sketch on a curved surface.... you can't so that. Also, please mention what version you are using, as we are all on a variety of releases, and only some people will be able to open your part file.
Further review shows your sketch is not fully constrained, nor does it have any dimensions on it. This is going to result in a very unstable model as you progress. I have to ask... have you had any training or run through any of the tutorials?
Try this link: http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
As noted - you an only create 2D sketches on a plane or planar face (2D is 2D).
There are other ways depending on your design intent.
I recommend that you do not use AutoCAD as your sketcher (nothing really wrong with using AutoCAD, but your sketch is not dimensioned, lacks geometry constraints and does not appear to be logically oriented about the origin.
I recommend you go through these
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
