Inventor Forum
Unable to see hidden lines from other parts in Inventor 2014
10 REPLIES 10
Message 1 of 11
Chris1969
1026 Views, 10 Replies
I don't know if it is a bug or a setting, but in Inventor 2014, when I work on a part inside an assembly, with hidden lines visible, I am not able to see hidden lines from other parts.
Can anyone help, is this a bug in Inventor 2014, or can this be changed in settings?
I really need that x-ray overview when projecting edges from hidden parts.
Thanks!
Brgds,
Chris
10 REPLIES 10
Message 2 of 11
samiharada
in reply to: Chris1969
I don't think there's an option to enabling what you are looking for, but
Ribbon [Tools] > "Options" panel > "Application Options" button
> [Display] tab > Inactive Component Appearance > Display edges
will give you somewhat close (hidden line will be shown in continous line,
not in dashed line though).
Hope this helps,
-Sami Harada
Inventor Framework QA
Autodesk, Inc.
Message 3 of 11
Ray_Feiler
I see the same thing here.
2012
2014
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 4 of 11
Chris1969
in reply to: Ray_Feiler
Thanks, I was also quite sure they were visible in the previous versions.
This is really a big issue for me, due to my workflow.
Please fix this Autodesk!
Brgds,
Chris
Message 5 of 11
Chris1969
in reply to: samiharada
Hi Sami,
It looks like there is a problem with the hidden lines missing in Inventor 2014, ref. RayFeiler
Is it an issue you will look into?
Thanks!
Brgds,
Chris
Message 6 of 11
samiharada
HI,
I need to understand why we are seeing different behavior first.
Please look at the attached screen capture from Inventor 2012 SP2.
I don't see hidden lines from inactive components while I'm doing in-place-edit.
(same as what 2014 update-1 does)
Would you mind sharing what is your workflow/dataset look like?
Thanks in advance,
-Sami Harada
Autodesk, Inc.
Message 7 of 11
Chris1969
Hi Sami,
Thanks for your reply.
Try to have a look at your own screenshot, I made a note on it.
Actually the hidden lines are visible. Try to do the same in Inventor 2014
My workflow is this:
1. I have a "part1" where the size and shape are known
2. Then I have a smaller "part2", where I know its shape and location inside "part1"
3. Now I need to make a cutout in "part1" for "part2", using its projected edges... Which are not visible in Inventor 2014.
Brgds,
Chris
Message 8 of 11
samiharada
Thank you for your clarification.
It turned out that this has been known as DID 1497386 in our product database.
The development team has been working on this to find out a solution.
Best,
-Sami Harada
Autodesk, Inc.
Message 9 of 11
Chris1969
Hi Sami,
Thanks for your answer.
Can you tell if this issue will be adressed in a hotfix/service pack?
Just because it is really anoying to work with.
Brgds,
Chris
Message 10 of 11
Chris1969
Hi again,
What is the status of this issue?
Is it something Autodesk is planning to fix, or is it just a downgrade we have to live with.
Brgds,
Chris
Message 11 of 11
samiharada
The code change has been made for this and the issue is not reproducible anymore in our internal test builds.
I believe the fix will be a part of coming update but we cannot commit anything here.
Hope this helps,
Thank you,
-Sami Harada
Autodesk, Inc.
