I am having troubles saving the file after I create my flat pattern. If I delete my flat pattern I can save but once I create it I am unable to save my file I get the following error message. This is not the first time this has happened I am sometimes successful at resoliving the issue my closing Inventor and restarting my pc but all attemps of this are not working. I would appreciate any and all help with resolving this possible Inventor bug.
Problems encountered while saving the document. Error(s) detected while writing segment MbBrepSegment in database V:\ENGINEERING\MRK Internal Projects\Router Workstation Shelf\Part\Router Shelf Hood.ipt Error detected while saving object of type MIxTransactablePartition in V:\ENGINEERING\MRK Internal Projects\Router Workstation Shelf\Part\Router Shelf Hood.ipt Error detected while saving object of type MIxPartition in V:\ENGINEERING\MRK Internal Projects\Router Workstation Shelf\Part\Router Shelf Hood.ipt The attempted write operation did not succeed. Part file may be corrupt. The database in V:\ENGINEERING\MRK Internal Projects\Router Workstation Shelf\Part\Router Shelf Hood.ipt could not be saved
What happens if you do a Manage>Rebuild All
Cut2 is not done correctly for a sheet metal part.
Mr. Mathers can I ask how you would go about doing Cut2 I am not getting errors on the cut.
@jasonabeddow wrote:
JD I tried the rebuild all idea and I get the same results.
I was expecting that Inventor would tell you that you have an error when you Rebuild All (does it not?).
You will not get error on the cut, but you need to understand cuts that go across bends.
See attached file (since I edited Cut2, you will need to fix the Flanges).
JD I noticed you went into the bend a little then went vertical were I stopped at the flat face and went vertical. Looking at your file I am unable to create a flat pattern on what you sent me.
I will have to look deeper into the problem.
You can edit the sketch as needed.
Thank you Carlos that worked never would of thought to use the split like that and the corners look nice as well. Thank you again.
Jason,
Any Inventor error referencing "segmentation in database" indicates a corrupt/damaged file.
It would be best if you started over from scratch or do no more than export your sketches.
Good Luck.
