Inventor Forum
Unable to remove hidden line from view to get shaded view
3 REPLIES 3
vzschoudhary
609 Views, 3 Replies
I made  a drawing, but after using ilogic (ilogic is in drawing,assembly, part) in it, drawing view of a particular part is coming in hidden line, other are shaded as u can see in image.
Drawing view is associative, all edges shown, level of detail is master, view style is Hidden Line Removal with Shaded
Computer Config:
Inventor 2013
Intel Xeon CPU
2.67 GHZ
8 Gb ram
Windows 7 64 bit
3 REPLIES 3
mcgyvr
in reply to: vzschoudhary
no attached image
Cadmanto
I would suggest posting an image of what you are seeing as well as the code for the iLogic rule you are using.
It is possible that your issue lies within your rule.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
pcrawley
Guessing here without the image, but it sounds like the BOM Structure of the offending part might be Reference?
Peter
