Hi Everyone,
Firstly I would like to thank anyone who take a few moments to help me with this, its causing me great problems. A large engineering company has sent me a selection of these files as 3D models and I have been unable to get them to open. I have tried in Inventor 2012 as well as Inventor 2015.
They tell me to open the STEP assembly file and say that all the other parts should just come into the model - but they don't. When I open it, I simply get a couple of lines on my screen as part of a 3D sketch.
Can anyone suggest how I might get them to open?
The file is shared here: https://onedrive.live.com/redir?resid=CEB2E96A40322F5A!151&authkey=!ADKzoKj5g_NWzQw&ithint=file%2czi...
Its about 30MB - so quite large. The Assembly file in the zip is z13529_asm.stp
Regards
Charlie
@Anonymous wrote:
They tell me to open the STEP assembly file....
They told you wrong as they don't understand CAD files.
They did not save as an assembly - but rather as 400+ individual part files.
You will first have to open each one of these part files to translate into Inventor.
It might be just as well that they saved in this manner, as Inventor might have had trouble opening 400+ parts from one file.
Once you get all the parts transalated, then try the assembly file. (But I suspect because of the way they saved this - you will have to re-assembly all of the parts. Good luck with that!)
I have looked at it some more and I don't doubt you, the file that they say is an assembly file ("z13529_asm.stp") references all the other parts in this directory though - so it appears to be a genuine assembly of all the other parts.
So is it just inventor that won't open it?
Something must open it as they are distributing this to their worldwide customer base!! (All the models are in this format!)
That isn't what I wrote.
Inventor opens STEP files just fine.
How much experience do you have with Inventor or Pro/E.
Did you not understand that you must open every file?
Depending on you use - some of the parts will need to be repaired as they don't pass Quality Check.
This fillet has a convoluted twist in one corner.
There are two ways to save the STEP file.
Individual parts and assembly each in a separate *.stp file (which is what you have if you examine the extracted zip folder contents)
or
one *.stp file containing all the part and assembly files in one STEP file.
The second option would open in one click if they had saved it that way.
Why do you say it is of no use?
Inventor will open the files just fine.
If the assembly file was within the step file - it would assembly everything, but since it is outside of the step....
I will try this in Creo (Pro/E) tomorrow, but I don't expect the behavior to be any different in Creo, and I am quite certain I will have to open all the part files before opening the assembly file.
I suspect they need to learn how to handle neutral format files as it sounds like they expect it to exhibit the same behavior as native format (Pro/E) part/assembly files.
Rather than be lazy and wait, I opted to download the Creo demo last night and see what happened - it opens the assembly file first time and produces this model! Excellent.
Never used Creo before, it seems nice. Would you say it is better/worse than inventor? (Especially on sheet metal?)
