Hi!
I'm using Autodesk 2014 Professional Student Version and I am unable to export or import the application options. When I try to, INV tells me that I tried to execute a not supportet process.
Is it possible to export or import the application options in the student version? Does anyone know this error?
P.S. The Attachment is in German, but says the same 😉
Thanks!
Hi! I would like to understand the behavior better. After you click Export button in Application Options dialog, do you see the error immediately? Or, it happens after you select a folder to save and click Save button.
Thanks!
Hi!
When I try to export, I am able to choose where I want to save them. As soon as I confirm the location, the error occurs. Afterwards I can click "okay" or close the window, but it will repeat to open itself until Inventor crashes or the application options switch to "colours". In the colours tab, i see many empty configurations. I will attach a Screenshot of it.
If I open the application options and choose the tab "colours" manually, i see the same. When I want to choose annother tab, the same error occurs (Tried to execute a not supported Process).
When I try to import, I am as well able to select a file, but as soon as I confirm, the error occurs.
I hope I was able to describe it a bit better.
Thanks for the help!
Hi! At the location you want to export Application Options to, do you have the privilege to write? Have you applied all the applicable Inventor service packs and updates?
Many thanks!
