Inventor Forum
unable to flat pattern
3 REPLIES 3
159 Views, 3 Replies
I've sent a part I modeled and tried to flat pattern to CF. It does have
different bend radii. Might that be the problem? ANy help would be
appreciated.
chris
3 REPLIES 3
Your mirror is off or something. Look close at mirror 3 and you will see that the
material is offset towards the outside of the box.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"cjay" wrote in message
news:3A4DEC0D1607CDA53DCAF21475C2F288@in.WebX.maYIadrTaRb...
> appreciated.
> chris
I will post a fixed up version under yours in Customer files. The biggest change was in
Sketch 5 I made the flange .0005 off of center. I also made a midplane by selecting the
outside faces to use for the mirroring.
Kent
Assistant Moderator
> appreciated.
> chris
Actually I stuck it in a new thread. Since the file in your post isn't zipped it pretty
much locks up Outlook Express so I can't just reply to it.. More people will be able to
see your files if they are zipped.
Kent
Assistant Moderator
