Inventor Forum
UNABLE TO FIND UNKNOWN TORQUE - please help
9 REPLIES 9
Message 1 of 10
729 Views, 9 Replies
Hi All 🙂
I started to learn Inventor a while ago and for the past few weeks I am really struggling with my assembly. (see pic and attachment)
The idea is tu turn the screw to move the torch arm up and down roughly 3 degrees each way.
I can get the lead screw to turn and move the assembly but so far have failed miserably to find the required torque to turn the screw. I tried with both Output grapher (values returned unusually high) and unknown force feature (couldnt get this to work at all 😞 )
The end of assembly weighs 3Kg which I referenced as the external force.
The unknown force keeps telling me to lock the DoF's but when I do the assembly wont move 😕
Could someone pont me in the right direction pretty please Smiley EmbarassedCapture.JPG
9 REPLIES 9
Message 2 of 10
JDMather
Before moving on to an advanced topic like DS, I would want to master the modeling environment.
I opened one of your part files and found that Sketch1 was not costrained and did not have any dimensions?
There were also several errors indicated in the feature tree?
Message 3 of 10
matthewbrindley
try this web site for torque http://www.engineersedge.com/calculators/torque_calc.htm
T=c * D * F
With the pivot point so close to the actuator the force will be a lot higher than the 3kg load on the end.
You could put your actual values in the calculator and see if it looks reasonable.
i7 3770k cpu
gtx680 4gb gpu
16gb ram
win7 64bit
Message 4 of 10
JDMather
in reply to: JDMather
What is the purpose of the 3 Move Face features at the end of this feature tree?  (Why 3?)
Message 5 of 10
The design had to be changed several times, guess I should have just changed the first "extend face" - Mea culpa for messy assembly, is this the reason why I am unable to find the torque? I started to use Inventor just over 2 months ago and I am learning on my own.
I can use the formula but the idea is to learn how to use the Inventor to do it.
Could you please advice on a way forward and what needs to be fixed apart from the errors visible in assembly tree, in order to solve for torque?
Message 6 of 10
JDMather
Are you aware that you can right click on a feature and select Edit Feature and change the distance?
Have you installed Service Packs 1 & 2 for 2014?
Message 7 of 10
JDMather
What process will you use to get this threaded rod into the threaded hole?
Message 8 of 10
mcgyvr
BFH (Big F'in Hammer) process 🙂
Message 9 of 10
in reply to: matthewbrindley
Thank you, already done the calc on paper but I need to  learn how to do it in Inventor.
Message 10 of 10
in reply to: mcgyvr
Right, Fixed the errors and made the thread full length but tbh thats not why I coulnt solve the thread torque problem. To get the thread in I would either constrain the axis or use cylindrical joint to provide for thread joint in DS, but I get the jist guys and thanks for all your kind and helpfull comments.
Apologies if the question was not expert enough for you.
