Hello, I'm trying to extrude a logo through a shape I have already created, however, "the attempted operation did not produce meaningful intersection edges from the face-face intersection. Try with different outputs."
Could someone please help me?
I'm using Autodesk Inventor 2014.
Solved by karthur1. Go to Solution.
I get the same error. You might try different options when you import the file. Can you post the original file that you are importing in?
You might have better luck recreating the image in a sketch.
