Inventor Forum
Unable to create Flat pattern
5 REPLIES 5
hansjb
308 Views, 5 Replies
Hello All,
I'm unable to create a flat pattern, Any suggestions would be appreciated.
Thank you,
5 REPLIES 5
jbogaard
in reply to: hansjb
Put dimensions and constraints in the sketch and use same thickness in the whole sketch.
Also be sure to enter sheet metal rules for the thickness of your sheet.
Good luck
JDMather
in reply to: hansjb
Problem 1
As indicated - Your sketch is not constrained - read this
http://home.pct.edu/~jmather/skillsusa%20university.pdf
JDMather
in reply to: hansjb
Problem 2
Your part is not uniform thickness, but sheet metal requirement is uniform thickness.
JDMather
in reply to: JDMather
Problem 3 you used Extrude rather than sheet metal tools?
JDMather
Problem 4 - you are doing too much work, get lazy.
Edit Sketch1 and notice only one side open profile needed.
